Is plugging the pcv OK?
Old Sep 20, 2005 | 08:54 AM
~JOSHUA's Avatar
Default Is plugging the pcv OK?
I'm wrapping up a complete polish of the engine bay. I'm also getting rid of all clutter, !wires,!air, and tidying up the ignition & fuel wiring. I'd like to get rid of all the pcv hoses while I'm at it. Can I plug the two outlets on the passenger side and the one on the driver's side and then run a breather on the oil fill spout? I know it's not emissions legal, but I don't run cats anyway. I' already non-emissions compliant. Is there any adverse effect or trouble I might run into?
Thanks.
Old Sep 20, 2005 | 10:10 AM
01 Red WS6's Avatar
I'm thinking of getting rid of my PCV stuff too when I get my new valve covers I'm still on the fence though
Old Sep 20, 2005 | 10:40 AM
ArcticZ28's Avatar
Thanks.
You could do the LS6 PCV conversion, that eliminates the tubing around the intake and such. I'm not sure that just a breather would be fine for the PCV system though. The PCV system typically pushes out a substantial amount of oil (later found in our intakes when you take them off). Eh... maybe it could work.
Old Sep 20, 2005 | 10:44 AM
oange ss's Avatar
you gonna build too much crankcase pressure and eventually blow out your main seals and unseat your rings...pcv system is a good thing
Old Sep 20, 2005 | 11:51 AM
~JOSHUA's Avatar
The seals were the first caution that came to mind. I know the breather would evacuate the passenger valve cover sufficiently, but there's all that pressure on the other side of the motor that has nowhere to go. I was curious to see if anyone else did this.
Old Sep 20, 2005 | 04:47 PM
SmaknaSS's Avatar
I run a PCV breather from the LS6 valley cover,another one from my old Ls1 plastic PCV on top of the valve covers and one in place of the oil filler cap. All these PCV vents have worked well so far for me.
