Mac headers install kit where to get?
Old Sep 20, 2005 | 09:17 AM
My1st Truck's Avatar
Default Mac headers install kit where to get?
Where can I get an install kit for a set of mac headers?
Old Sep 20, 2005 | 09:18 AM
AdamSS's Avatar
what do you need ?
bolts and nuts ???
Old Sep 20, 2005 | 09:42 AM
Nuts, bolts, gaskets.
Thanks
Old Sep 20, 2005 | 09:46 AM
GregWS6&z28's Avatar
-reuse stock manifold bolts
-buy new GM metal gaskets
-only other bolts are for the y-pipe to collector flange, so you can get pretty much any length that will fit through and use washers and a nut on the opposite side. (dont depend on the threads in the flange to hold)
Old Sep 20, 2005 | 09:56 AM
natronathon's Avatar
Here's what i would do....
Go to one of the sponsors (speed inc, or thunder racing are my favorites)
Get:
Stage 8 Locking fastners Hex head
GM Metal Gaskets
O2 extensions (i dont know if they are needed for the macs or not....)
O2 sims, if you aren't going to delete them
1 3/8 inch expansion plug for your intake if you are going to delete egr and air
Old Sep 20, 2005 | 10:03 AM
AdamSS's Avatar
You don't need O2 extensions. the passanger side will reach without the problem. The driver side, you need to unhook the little bracket and pull the harness. Do a search on my name in this forum and you'll find more info. But no doubt - it will reach. Don't waste your money on extensions !!!!
I reused stock header bolts and gaskets. All you need to buy is bolts for Y-pipe ! You can get those from any hardware store...
