flowmaster only help...
Old Sep 20, 2005 | 10:32 PM
monsterbreather's Avatar
Default flowmaster only help...
what part number flowmaster do i need if i wanted to weld one in my self.also do i need any adaptors? 2001 z28. thanks for help
Old Sep 20, 2005 | 11:28 PM
Brent@LPE's Avatar
call tom @ epp 260-483-9300!
Old Sep 20, 2005 | 11:37 PM
SUX2BU's Avatar
First off. why do you want a flowmaster?
Old Sep 21, 2005 | 11:30 AM
Default re
sound mainly. i called tom setting it up thanks!!!!
also what pipe do you guys use in front of the muffler the stock one is lame,all flatened out from the factory.
i just want to use the stock tail pipes im into the stock look.
Old Sep 21, 2005 | 11:43 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Leave him alone...it is one of the best sounding cat-backs out there when teamed with the stock manifolds and cats.
Old Sep 21, 2005 | 11:58 AM
LS69TA's Avatar
The factory replacement 80 series will fit pretty much where the stock muffler is, depending on how you cut it. You may have to add a little pipe if you cut too much off of the outlet pipes, but other than that it's a direct fit.
Old Sep 24, 2005 | 10:27 PM
ls69ta apparently you have never been there on this muffler install.
80 Series Crossflow Muffler, 2.50" IN (O) / OUT (D) 42583 will not just fit in!!!! its about 10 inches shorter and requires a good bit of tight welding and more than just a little pipe. it will need special adaptors that are longer in size than standered ones.....i had to prefab mine. it looks great but will take some time and skill. hope this helps others.
Old Sep 24, 2005 | 11:04 PM
Redneck Z's Avatar
A new Y-pipe won't do anything and the corkmaster won't do much. Why do you wan't such a restrictive muffler? You can have a better sounding muffler without putting such a restrictive one on. If you're looking for a performance gain, don't go with the flowmaster.
