Help
Old Sep 25, 2005 | 02:11 PM
monsterchevylizzard's Avatar
Default Help
Does anyone know what the function of this item in the picture is ? It is located just below the intake on camaros and firebirds, but I dont think it is on corvette engines.
I think it has something to do with the engine cooling, but I dont know if it is pushing fluid out of the block or supposed to be sucking in coolant ?
Does it need to be connected to the bottom of the radiator or just connected to the coolant overflow tank ?
Old Sep 25, 2005 | 02:46 PM
2001NBMZ28's Avatar
That's the front coolant pipe connection - hose runs from it to the second connection under the radiator cap - just below the coolant overflow (top) connection.
Old Sep 25, 2005 | 02:58 PM
If Im using an aftermarket radiator with only one overflow valve on the top, can I just run that connection under the intake to the overflow container ?
I have it set up that way now, but the water in the overflow tank is boiling, so I think I am going to have to change it.
Old Sep 25, 2005 | 03:14 PM
davered00ss's Avatar
Moderator
Coolant line for the TB. Most people do the throttle body bypass and cap off that line.
Old Sep 25, 2005 | 03:30 PM
SSBLUBYYOU's Avatar
Like davered00ss said....most people bypass that and just plug/cap it off!!!
