hooker aerochamber muffler only???
Old Oct 2, 2005 | 12:35 PM
Raise's Avatar
Default hooker aerochamber muffler only???
i know on the hooker catback, the over the axle pipe and the muffler hook together by flange and bolts. thunderracing has a hooker aerochamber muffler only that is a direct fit for a stock system. it has the stock inlet and outlet sizes...which are 2.75" inlet and 2.5" outlet. my question is, will this direct replacement muffler have a flange on the muffler?? i wouldnt think it would cuz there would be no way to hook it to the stock over the axle pipe. im guessing it just has a slip fitting sticking out so u can clamp them together. im guessing the outlet pipes would work the same. anyone know??
Old Oct 2, 2005 | 02:46 PM
patSS/00's Avatar
Don't know the answer to your question, but hope you noticed that you can't get the 2.75 inlet and 2.5 outlet on the same muffler.
Old Oct 2, 2005 | 03:32 PM
Cstick's Avatar
There is no flange. It slips together. Cut the stock pipe going to the muffler as close as you can to the stock muffler. The driver side tail pipe will need an extension, as the Hooker muffler is shorter than the stocker. Not a big deal to put together, I have had mine for a while now.
Old Oct 2, 2005 | 03:44 PM
Raise's Avatar
thunderracing.com has the stock replacement hooker muffler....i guess the outlet is 2.25" instead of 2.5". sorry...my fault. so what are the stock outlet pipes...2.25" or 2.5" ??
