90mm intake question
Old Oct 4, 2005 | 11:59 AM
brandonppr's Avatar
Default 90mm intake question
I have a MS3 cam, prc stage 2.5 heads, LT 3'' duels, bullets, 85mm maf, LME 5.7L
3500 stall.
if I put a 90mm tb and intake would this help or hurt performance?
what brand should I go with also?
thanks
Old Oct 4, 2005 | 12:07 PM
JakeFusion's Avatar
Super Hulk Smash
The FAST LSX90 would help quite a lot, especially if it's port matched to the heads. 20-25rwhp wouldn't be unreasonable.
Nick Williams 90mm Throttle-Body is the only way to go.
Old Oct 4, 2005 | 12:26 PM
brandonppr's Avatar
should I upgrade my stock 28lb injectors or would they be ok
Old Oct 4, 2005 | 12:31 PM
LSUxBlake's Avatar
The injector thing varies for everyone, I've heard of people running 100% duty cycle with 410rwhp yet I'm not maxed out (though I'm close) with the smaller 99 injectors and 455rwhp. If you can afford it though, I'd recommend you step up to some bigger injectors now.
By the way, get a FAST, I like mine.
Old Oct 4, 2005 | 12:34 PM
brandonppr's Avatar
what size would you reccomend?
Old Oct 4, 2005 | 12:38 PM
LSUxBlake's Avatar
Well it really depends on your future mods. It's not good to run too big of an injector even if you tune it right, as it wont spray as efficiently. I believe my new setup is going with 32-36lbs, although I'm waiting on Allan to hear for sure.
Old Oct 4, 2005 | 12:40 PM
brandonppr's Avatar
thanks for the help
