Spark plug gap question...
Old Oct 5, 2005 | 07:58 PM
Ric's Avatar
Ric
Default Spark plug gap question...
After resetting my PCM, it STILL PINGS!!!
Could I have set the plug gap too wide??? They're at .060" right now.
Old Oct 6, 2005 | 12:14 AM
black00TA's Avatar
check elsewhere for the problem.
which plugs did u use?
Old Oct 6, 2005 | 06:59 AM
Ric's Avatar
Ric
I've been corrected for this before, but right now it has Bosch Platinums in it. There again, it didn't ping before the lid went on.
Old Oct 6, 2005 | 08:21 AM
taintedmeat's Avatar
You're not running 87 octane are you?
Old Oct 6, 2005 | 08:34 AM
Ric's Avatar
Ric
Nope. Every now and again when it's stupid cheaper, I'll drop to 92, but most of the time, it sips 93-octane.
Old Oct 6, 2005 | 12:09 PM
black00TA's Avatar
if its REAL hot where u are, u could be gettin extremely high IAT. and that could be pulling off a lot of timing.. and causing knock.
Old Oct 7, 2005 | 10:28 PM
Ric's Avatar
Ric
Here's what all I've done so far:
TB bypass
Lid
Bosch Platinums gapped at .060"
EGR mod
I'm in NORTH Georgia(any further north is NC), in the hills, and it's been hitting 85 on a hot day lately. So I doubt a hot IAT would be the culprit. I'm flat-out STUMPED.
Old Oct 8, 2005 | 03:28 PM
Race-Prep's Avatar
Suspended Sponsor
I have seen this before, look into a cooler heat range plug and it will likely fix the problem I would try the TR5 or maybe the TR6, I understand most people use these for power adders but it works real well and if you gap them to .050" they should not cause a problem, it allowed us to make like 30 more on a car that would ping on the stock tune with 100 octane before the fix!
-Bryan
Old Oct 8, 2005 | 08:55 PM
snksknr's Avatar
Default right now it has Bosch Platinums in it
I read somewhere in here that platinum plugs retain heat causing the fuel mixture to predetonate.
Old Oct 8, 2005 | 10:04 PM
Ric's Avatar
Ric
I just wasn't thinking when I got these plugs. Guess I'm gonna pop'em out, gap'em at .050", and pop'em back in. If I get a high-end plug next time, I'll spring for those $20-each Iridiums.
Which is colder, the TR5 or TR6?
Old Oct 9, 2005 | 07:37 AM
Patrick G's Avatar
LS1 Tech Administrator
TR6 plugs are colder. Part number 4177. Cost $1.59 each at O'Reilly's. I have them in my car gapped .045".
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 9, 2005 | 08:40 AM
shouldaboughttheZ's Avatar
It looks as tho you don't have any big mods (headers, catbak, tune). The NGK TR55's should be good enough. I run them gapped at .055. Never had a problem with them. People who run NOS or Forced Injection usually run the NGK TR6.
Like stated above, I have heard the same about the Bosch plugs.
Old Oct 9, 2005 | 10:34 PM
Ric's Avatar
Ric
Good stuff, y'all. Thanks for the help.
Gonna close the gap on what I got, and hopefully I'll have LTs to put on with my next plug change.
Old Oct 9, 2005 | 11:39 PM
black00TA's Avatar
tr6 might be a little extreme for your setup.
tr55 should be great for your setup even with LT's.
i run tr55's @ .055
and they have been nothing less than perfect.
