To remove AIR or not to remove
Old Oct 5, 2005 | 08:37 PM
vMaster0fPuppets's Avatar
Arrow To remove AIR or not to remove
I just finished installing my LTs and ORY and I now either must do the restrictor plate mod or completely remove the AIR to stop the ticking.....
I am already going to have my rear O2 codes removed and will have to have my AIR removed to make the car emmissions legal after this.
I live in PA where I believe they only do the ODB II emmsions test with no visual. I read once that to pass the OBD II you must have atleast 2 systems out of the AIR, EGR, and rear O2s active. If this is rue I will fail inspection so I cannot do the AIR removal. So is this true?? Anyone know how that works??
Also does the AIR have any other function other than to help the cats out. Does it help with gas milages?? Does it add performace?? Does it have any other effects either positive or negative??
Old Oct 6, 2005 | 01:46 AM
Old Oct 6, 2005 | 01:56 AM
co.6z28's Avatar
remove it. save weight.
Old Oct 6, 2005 | 02:26 AM
zspot98's Avatar
The air system neither helps or hurts any performance just there for emisions. It is really simple to take out, maybe 20 minutes worth of work. It will clean out the engine bay a little and help w/ weight if you remove the whole system (pump included).
Old Oct 6, 2005 | 07:18 AM
peterock98's Avatar
Take it out.
Old Oct 6, 2005 | 07:22 AM
Michael02hawk's Avatar
Can you explain what the ticking sound is your hearing? When is happens, and such?
I'm having a ticking sound also, been trying to pin point it for about a month so far.
btw, my AIR is in tact, living in NY, I'm leary about removing it.
Old Oct 6, 2005 | 07:31 AM
peterock98's Avatar
I'am in the Bronx and I removed mine.I had my car inspected a couple of months ago and now they check if there's any dtc codes and that's it.They didn't even open the hood or drive it on the dyno.The tech told me this is the new procedure for 1996 and up cars.
Old Oct 6, 2005 | 08:12 AM
Cocked N Locked's Avatar
This is the same thing they do in Indiana. I just took mine yesterday and it passed. no visual, no dyno, just plug in the cable and as long as you throw no codes when you turn the car off and on again it will pass just fine. I have no egr, no air, no cats, no rear o2's. You will be fine
 Michael S. Palmer
Old Oct 6, 2005 | 11:54 AM
FstBlkz28's Avatar
DELETE IT
Have the codes deleted/turned off w/ a tuning program.
Old Oct 10, 2005 | 11:22 AM
gillbot's Avatar
Mine passed emissions with the rear o2's deleted and the AIR removed. If you do it right, the OBD-II test won't even know they were there to begin with.
Old Oct 10, 2005 | 11:25 AM
HAUS1's Avatar
Take that gargabe out. Get the codes tuned and you will be good to go.
Old Oct 10, 2005 | 01:41 PM
jlashley2001ss's Avatar
let me ask u guys this..... by removing the AIR system with a car that still has cats(sig below) will the cats eventually burn up??
