Porting Question
Old Oct 9, 2005 | 01:30 PM
zapp168's Avatar
Default Porting Question
I am going to port my first throttle body. I have done searching and it all looks fairly simple. I am left with one question. The bump stop part of the project. I filed down my bump stop back when I got my car in 98 until I got 4.74 volts, however I am now noticing that the throttle plate still does not look quite fully open. Is it correct to make the plate open full then re-adjust the TPS to read max voltage? Or does it even matter?
Thanks
Old Oct 9, 2005 | 02:10 PM
superGMman's Avatar
If your asking if the throttle plate is supposed to open completely the answer is no.
Old Oct 9, 2005 | 04:49 PM
zapp168's Avatar
That was the question....thank you
Old Oct 9, 2005 | 08:22 PM
black00TA's Avatar
you will throw a code if the blade opens completelly.
