Placing little spring on Y-pipe?
Old Oct 11, 2005 | 10:40 PM
Jimmy P's Avatar
Default Placing little spring on Y-pipe?
I remember seeing a thread of someone that placed a small spring in the area between their driver side Y pipe and the frame. My Y-pipe keeps on rattling by the drivers side as it touches the frame right under the drivers seat, close to were the crossmember is. I know a spring would stop that. Anyone know about what I'm talking about? Thanks
Old Oct 12, 2005 | 03:52 AM
riddler's Avatar
Veteran: Air Force
Yup, you weld a valve spring where it's hitting and it keeps it from banging. You can put some foam rubber in there too it you want to get psyco
Old Oct 12, 2005 | 01:42 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Shove a piece of rigid foam insulation (yes, the kind that goes in walls) in there. Call it a day (learned technique via a reputable exhaust guy who likes to fix things the simple way- if your car isn't in car shows with mirrors underneath- who is going to know?).
Old Oct 22, 2005 | 06:11 AM
Jimmy P's Avatar
Thanks for the advice. I have a question for you. Have you done that to your car? I went to Home Depot and bought piece rigid foam insulation. I got the thickest one they had. Put it on, and for the first 20 minutes it seemed to work nicely, the banging was tottaly gone. After a while, it starts again. I figured the piece must of fell off. I put my car up on a lift, and we notice some type of red melted substance all over the driver side y-pipe were I had placed the rigid foam insulation. It didn't fall off, but instead it melted off.
Old Oct 22, 2005 | 07:35 AM
!LS1 11 Second Club
Use the kind that has metallic foil outer layer.
Old Oct 22, 2005 | 09:24 AM
Caribe's Avatar
After screwing around getting my y-pipe from banging I just invested in this LS1 bump stop hanger. It stopped the bumping and is available at Thunder Racing:http://www.thunderracing.com/catalog...&vid=3&pcid=54: Scroll Down Page
Old Oct 22, 2005 | 10:04 AM
Caribe's Avatar
There is a bump stop for sale here:
https://ls1tech.com/forums/lsx-parts-sale/398556-eibach-prokit-mufflex-y-pipe-clamp.html
Old Oct 22, 2005 | 10:16 AM
Jeremiah's Avatar
wedge a piece of wood or a pry bar between the pipe and the floor/frame and jack up the rear of the pipe to twist or tweak the pipe. This will give you the clearance you need, I had to do this with my Jet hot Y pipe. Also if one side hanges lower than the other you do the same by wedging a piece of wood between the tight side and jacking up the low side to twist it. This will close up the loose side while opening up the tight side a little. If you use a pry bar be sure to wrap it with a peice of card board or something to keep it from scratching the pipe or the coating.
My Jet hot was right against the floor and this fixed it with no damage at all on the first try.
