QTEC cutout open/close switch...
Old Oct 12, 2005 | 10:05 PM
DeViOuSwOn's Avatar
Default QTEC cutout open/close switch...
I have everything but the switch. What kind of switch do I need? There are many to choose from and want to make sure I get the right one. Do I need a 2 position, 3 position, momentary etc? Thanks!
TJ
Old Oct 12, 2005 | 10:08 PM
bastien's Avatar
use the search button. there are many threads on wiring the e-cutout.
Z28LS1camaroguy's Avatar
im pretty sure youll be just fine with a two position switch from any autoparts store.
Old Oct 12, 2005 | 10:14 PM
bastien's Avatar
https://ls1tech.com/forums/showthrea...=wiring+cutout
Old Oct 12, 2005 | 10:34 PM
DeViOuSwOn's Avatar
So my understanding is this...
I need a 3 position switch correct? Position 1 is neutral, position 2 is up and position 3 is down? Let me know if this is correct.
Old Oct 12, 2005 | 10:54 PM
glennhl's Avatar
I have a street pro cutout and it uses a three position momentary switch.
Old Oct 12, 2005 | 10:59 PM
DeViOuSwOn's Avatar
So a 3 position, either fixed or momentary will work correct? As long as there is a neutral and two others...
Old Oct 12, 2005 | 11:54 PM
spy2520's Avatar
i think it needs to be a 3 position momentary switch.
Old Oct 12, 2005 | 11:59 PM
DeViOuSwOn's Avatar
or a fixed 3 position. Keep it in the middle(closed). Flip it up until it's open, the flip back to middle. Then when you want it closed, flip it down until it's closed, then back to the middle...?
Old Oct 13, 2005 | 06:44 PM
DeViOuSwOn's Avatar
Bizzump
Old Oct 13, 2005 | 08:15 PM
spy2520's Avatar
yes iguess that would work.
Old Oct 13, 2005 | 11:06 PM
smash's Avatar
I went to the dealership, and bought a convertable top switch. I wired it (well, my friend did) up so that it looks stock, except I have no convertable top!
Old Oct 14, 2005 | 12:13 AM
slow's Avatar
You need a DPDT switch wired up for reversing for a electric cutout.
the convertible top works like this, so that works great, so does a window switch
Ryan
Old Oct 14, 2005 | 11:55 AM
DeViOuSwOn's Avatar
Ryan
So a window switch or convertible will work?
