Nick Williams Thottle body problem?
Old Oct 23, 2005 | 03:46 AM
marine02ss's Avatar
Default Nick Williams Thottle body problem?
I purchased a NW TB a while back Im having problems when taking off,it feels likes it stuck when I try to take off,anybody experience this??/?
Old Oct 23, 2005 | 04:44 AM
Bo White's Avatar
It may have sucked some grit into it sometime or another and its probably scarred the housing where the blade rests at idle. Take it off and spray it out good with brake clean and move the idle screw 1/8th turn or so to move the blade slightly to a new area of the housing, that amount will not affect idle speed.
Old Oct 23, 2005 | 02:07 PM
Nick Williams's Avatar
Try what Bo said. If that doesn't fix it I would be happy to take a look at it for you.
Nick
Old Oct 23, 2005 | 09:28 PM
marine02ss's Avatar
Hey I appreciate the advise Bo,Nick I had cleaned it a while back but still the same problem, Ill try to open the blade a little bit, Ill see how it works Thanks Nick for standing behind your product,all I get is compliments,your TB is awesome,Ill get back at you.
Old Oct 23, 2005 | 09:48 PM
My email is nickw_61@yahoo.com. Let me know. If you send it back and there is a problem I will fix it or send you a new one.
Nick
Old Oct 24, 2005 | 07:00 AM
transam1998's Avatar
Mr. Williams also recently contacted me to give me advice on an idle issue. If anyone is looking to go with an aftermarket throttle body, Nick Williams is the way to go!
