New exhaust installed!!!!!!!
Old Oct 27, 2005 | 03:39 PM
hunterdawgs's Avatar
Default New exhaust installed!!!!!!!
Sounds bad@$$ @ WOT,NO drone @any rpm and probably not loud enough@ idle for some of you guys though. .Also no rasp,this is just what I was looking for and I bet when you guys hear it some of you will be interested also. I was skeptical before I heard it because you don't hear much about Bassani on here but I guarentee some will consider it when I get some sound clips.
Old Oct 27, 2005 | 03:46 PM
NOBR8KSS's Avatar
Sound clips?...Pics?
Old Oct 27, 2005 | 05:17 PM
Scotty-Z's Avatar
We need sound clips! There's hardly any clips out there of Bassani!
Old Oct 27, 2005 | 08:21 PM
The driver side of the ORY is banging when the motor torques so what is the piece that I need ,a torque arm or torque link?
Old Oct 27, 2005 | 08:50 PM
ls1rocker's Avatar
if you put in a poly motor mount atleast on the driver side it will get rid of that banging
Old Oct 27, 2005 | 08:59 PM
What will that do for the quality of ride and what about the torque arm or link I suggested?
Old Oct 27, 2005 | 10:16 PM
CRL 01 SS's Avatar
Had the same problem with my SLP y-pipe a few years back. I got the guy at my local exhaust shop to take a big rubber exhaust mount, and put a piece of the steel rod (the kind they usually use to hang the exhaust from the rubber mount) thru the rubber mount. He then put the rubber mount in between my floorpan and the y-pipe, and welded the steel rod to each side of my y-pipe to keep the rubber mount in place. No more banging.
Old Oct 28, 2005 | 02:31 AM
ls1rocker's Avatar
the poly mount is stiffer than the stock rubber mount and will restrict the movement of the motor more. as for the ride, you probably won't even notice it, well except no more bang.
the link or strap you are thinking is probably where people take a ratchet tie down strap or equivalent and physically strap the motor down. possibly same effect, probably cheaper, but the poly mount is well worth the time to put it on and you don't have to worry about people tellin you that there is a tie down strap in the engine compartment
Old Oct 28, 2005 | 06:44 AM
99HUGGRSS's Avatar
i've got bassani on my ss with kooks and catted y-pipe and it is the ****!! looks good and sounds awesome.had it installed about 2months ago.worth the money, in my opinion!
Old Oct 28, 2005 | 06:46 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I think that the cats make it less raspy.
Old Oct 28, 2005 | 06:56 AM
99HUGGRSS's Avatar
i thought that was going to be an issue with the cats, but i was wrong. it sounds very nice at any speed ,for an auto. when i first started it, after the install i had instant wood!! i coudn't contain myself. LOL
Old Oct 28, 2005 | 08:40 AM
mrr23's Avatar
i know on the bassani tru-duals, it comes with a rubber mount on the driver's side pipe to keep it from hitting the underbody.
Old Oct 30, 2005 | 12:52 AM
Gonna get the poly motor mounts to take care of the Y banging and I think I might get dual-duals instead of the single 3" round slash cut tips.
Old Oct 30, 2005 | 12:54 AM
Full-Force's Avatar
Good decision on the poly motor mounts.
Old Oct 30, 2005 | 11:02 AM
slimcracka's Avatar
yeah but good luck installin them youll prolly have to uninstall the headers and y pipe....i would get the y pipe strap from muflex..
