Y-pipe bumping floor
When I had my duals built I didn't use cats and we incorporated a Dr Gas frame clearance pipe under the crossmember just behind the driver's side collector. This has made a ton of difference. I would recommend to those that are having a custom Y built to consider using one of the Dr Gas clearance tubes. If nothing else, swap in a poly mount on the driver's side.
---or---
take the time to put poly motor mounts in. worth every penny, no adverse side effects (like the vibration you get from poly trans mounts). you'll be happy that you didnt bash your floor or rig your exhaust
I did the exact same thing and it worked great, stopped every bit of that vibration and rattling
Straight headers going on the camaro
