Cutout Switch Wiring Problem Help
Old Nov 8, 2005 | 05:51 PM
z28C4maro82z's Avatar
Default Cutout Switch Wiring Problem Help
Please I need some help here
I got the switch, I got the wires all ran underneath the cutout hooked up and now I need the wires to the switch. I've no idea on how to run them to the actual switch itself. There were 8 wires connected to it and just need to know how to run the wires. I'm so lost
PLEASE HELP THANK YOU
They are in the shape of a square and it's the QTP switch I believe
Old Nov 8, 2005 | 09:10 PM
Z28LS1camaroguy's Avatar
its doesnt have some sort of sticker or instructions on how the switch will work, in terms of which is the ground and postive plug?? if so all you need is to ground the switch and run the positive side to the accessorie part under the hood its a bolt with a nut on it with a red cap by the fuse box, and then it should work.
Old Nov 8, 2005 | 10:06 PM
bastien's Avatar
if you're using the factory QTP switch, it's basically a red(+12 power) and black(ground) wire..
That's all there is to it
Old Jul 28, 2006 | 06:42 PM
Shamson5.7's Avatar
bump to this. I cant fuckig figure this thing out
Old Jul 28, 2006 | 06:53 PM
Shamson5.7's Avatar
I have the "stock" QTP switch and I REALLY need some help. I have no clue how to wire this damn thing and the cut out remains open. I NEED to at least get it shut so I can drive the car. ANY help would be GREATLY appreciated
