whats this part
Old Nov 11, 2005 | 09:50 AM
02WS6Bird's Avatar
Default whats this part
Was pulling the intake manifold off of the camaro last night and there was a plastic? hose that lead from the intake plenum (on the passenger side then splits and sends hose into the rear of each valve cover going into the heads...Well as i tried to pull it off from the plenum, i noticed the hose was cracking and had a tiny hole in it near the driver side head entrance. The Hose in turn, near the plunum then broke
Car has 140K on it... I need to know what this part is, what's it do, can it be replaced, and where can i get the replacement
Old Nov 11, 2005 | 10:00 AM
02WS6Bird's Avatar
also theres some sort of harness, or sensro in back cant really think of what it is called i think it goes to the brake booster vacuum hose.... The wires that connect to the harness on the back came out of the harness/clip i think they are Red green and purple can anyone show me how they go back in? or whatever? picture instruction etc? thanks!
Old Nov 11, 2005 | 10:18 AM
conan's Avatar
The two hoses your talking about is your pcv lines, it vents crank case press. On the back of the intake is your MAP sensor, dont know what order the wires are.
Old Nov 11, 2005 | 10:48 AM
WILWAXU's Avatar
It's either the PCV or AIR system hoses.
Old Nov 11, 2005 | 01:21 PM
02WS6Bird's Avatar
AIR system is GONE haha
So the PCV- what can i do to rplace that?
Old Nov 13, 2005 | 11:18 PM
02WS6Bird's Avatar
Anybody have a PCV hose i can get buy etc? also the lil harness in the back of the intake manifold...w/ 3 wires? MAP sensor maybe? how do i get the wires back in the harness mine slid out...thanks!
Old Nov 14, 2005 | 12:25 AM
TAQuickness's Avatar
you can get pig tail harneses from a GM dealer. give them a call and tell them what you need.
Old Nov 14, 2005 | 12:53 AM
camaross305's Avatar
i had a leaking pcv hose that was cracked on my old car....cost 145 from gm for the whole line i said screw that and taped it up with some black plumbing tape and it worked fine
Old Nov 14, 2005 | 01:32 AM
bshell's Avatar
LS6 valley cover conversion is about $60 in parts and will relocate the pcv from the valve covers to the valley. If you have to remove the intake to replace the broken pigtail, you would have done the hardest part of the install already.
