1st pics!!!! C5 Accessory Drive on an LS7!!!
Old Nov 15, 2005 | 11:34 PM
John B's Avatar
Moderator
Default 1st pics!!!! C5 Accessory Drive on an LS7!!!
I only had 30 minutes to play tonight and think we've all made this a little too difficult and without trying to slam GM I couldn't believe my eyes tonight Of course it doesn't take me long to come up with what I need so I slapped on a C5 accessory drive onto the front of my LS7 crate motor and low and behold....it's virtually a perfect fit as far as the spacing! Granted I didn't tighten all of the bracketry down tight or put the PS pulley in place but measuring the set-back on the belt tensioner revealed the same 4" setback from the right cylinder head as the waterpump belt location +/- 1/32"!!!
I think we're in business here when you look at the quick couple of pics!!!
Attached Thumbnails 1st pics!!!! C5 Accessory Drive on an LS7!!!-brkt2.jpg   1st pics!!!! C5 Accessory Drive on an LS7!!!-brkt1.jpg
Old Nov 16, 2005 | 12:07 AM
Builder's Avatar
Good job, John! That's great. Maybe that won't be so painful afterall.
Wish I knew more about the LSx series. Is that an A/C unit down low? What about putting the A/C (low) and ALT (high) on the other side?
Thanks,
-- Scott
Old Nov 16, 2005 | 06:14 AM
98blackSS's Avatar
Thanks John.. Great info - especially for us
Old Nov 16, 2005 | 06:40 AM
chuntington101's Avatar
builder, why are you bother about A/C?? just go a bit faster and open the helicoptor vents! hehe
does look to make the fitment into your car a little easier though!
Chris.
Old Nov 16, 2005 | 09:00 AM
LS2 V8 Miata's Avatar
Default Hardware's the easy part
John,
What are you going to use for a PCM and wiring harness to run your LS7 crate motor, that's the problem I'm interested in hearing the answer to.
Old Nov 16, 2005 | 09:22 AM
98blackSS's Avatar
Originally Posted by LS2 V8 Miata
John,
I believe he's waiting on the beta release of LS7 HPtuners.
Old Nov 16, 2005 | 11:59 AM
Chrisrokc's Avatar
Also, whats the plan for the dry sump.
Old Nov 16, 2005 | 01:07 PM
NOSjohn's Avatar
Restricted User
Great info. mr. John. Dry sump parts are pricey.
Old Nov 16, 2005 | 01:18 PM
John B's Avatar
Moderator
You're welcome guys!
What I believe you're looking at is the Power Steering Pump without the pulley on it (the pulley was removed to access the bolts that hold the pump to the bracket). From the factory, the A/C is on the passenger low side.
I ordered a Peterson system complete with catch can for under $500.
Old Nov 16, 2005 | 02:06 PM
Chrisrokc's Avatar
Nice, oh I am guessing you are putting this in a vette?
Old Nov 16, 2005 | 06:27 PM
KJ's Avatar
KJ
Looks good John!! I hope to have more info for you guys on ECU's and a harness when I get back from PRI!!
Old Nov 16, 2005 | 07:03 PM
John B's Avatar
Moderator
Sorry Chrisrokc, this is going into my '88 Monte SS
Old Nov 16, 2005 | 07:27 PM
Chrisrokc's Avatar
Wo nice! Thats even cooler! Reason why I asked it because there has been alot of talk about how there might not be enough room in the C5 Vette for the dry sump system.
Old Nov 16, 2005 | 07:43 PM
98blackSS's Avatar
Oh we'll find somewhere, trust me
Old Nov 17, 2005 | 08:15 AM
TAF Motorsports's Avatar
So did the LS7 come with the Pump?
Old Nov 17, 2005 | 08:22 AM
98blackSS's Avatar
yes.. no tank or lines though.
Old Nov 17, 2005 | 08:30 AM
hmmm
Old Jan 12, 2017 | 05:27 PM
bmf5150's Avatar
Anyone know if the c5 accessory will line up with ls7 accessory?example ,c5 alternator and power steering line up with C6 ls7 dampener?
Old Jan 12, 2017 | 07:11 PM
John B's Avatar
Moderator
Hmmm....didn't you read my post correctly that's exactly what I used! The crate motor uses a C6 LS7 dampener!
Old Jan 13, 2017 | 11:27 PM
bmf5150's Avatar
I miss read,sorry...thanks John
