stripped
Old Nov 21, 2005 | 01:21 PM
99FormulaM6's Avatar
Default stripped
i was trying to put in the water temp sender in the location thats right above the starter. its supposed to be a 8mm allen, but the 8mm wasnt working at all. so, now how do i get it out?
Old Nov 21, 2005 | 10:22 PM
WILWAXU's Avatar
You sure it's not a Torx?
Old Nov 22, 2005 | 06:54 AM
yup. 8mm allen. the fitting is brass, and its probably corroded some around the threads since its holding back coolant. and since its never been taken out, and the car is a 99...its stuck pretty good. when it got to the point the allen wasnt working, we tried to use a torx but that didnt work either.
