y pipe
Old Nov 24, 2005 | 04:18 AM
shaun's Avatar
Question y pipe
can any one recommend a off road y pipe. i have a 98 z with stock manifolds and i have a 3 inch random tech ss exaust. ill go with a off road if i use 02 sims and if it will no effect driveability. will it effect the cars drivability?
and also the ground clearance.
thanks for the help guys shaun
Old Nov 24, 2005 | 11:10 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I beleive Bassani makes an ORY for stock manifolds. I've never tried it, but their other products are always high quality (I've used their catbacks and headers/Y-pipes) so I'm sure that would be as well. I know both Thunder Racing and Tbyrne (site sponsers) sell Bassani products so I'd check their websites first.
Driveability should not be adversely effected. MPG might improve a little and the exhaust note will be louder and more raspy. You should pick up a bit of power too. Of course the exhaust will smell a lot dirtier as well. Using the O2 sims will keep the SES light away and the PCM will never know that the cats are missing then.
As for ground clearance, you will likely lose a little on the drivers side because you will be replacing a flattened pipe with a larger diameter round pipe. Won't be a huge loss of clearance though.
