Why not port a ZO6 MAF?
Thanks,Larry
What you have described sounds logical. I just haven't experienced those issues after porting the MAF. Porting the MAF resulted in an increase in intake air flow & the ECU or PCM adjusted the fueling for the increased flow through WOT. So, in my case it was OK. Porting a MAF even larger than a smaller intake/TB can also be beneficial in reducing the pressure drop on the intake side. So long as the MAF can record the increse in air flow, the ECU should adjust to it. My A/F ratio @ WOT was 12.8-12.9 before & after porting. Took some time to adjust & I should mention that there was enough capacity in the aftermarket injectors & fuel pump to handle the increase.
I don't know about the screen straightening out turbulant flow thing either. The screen is a restriction in my opinion; no more no less. Kinda has the same effect as a turbonator. It restricts flow to improve gas mileage, IMO. Took the screen out of my Buick Rendevous & lost .2 MPG & the car feels as bit stronger (more air/more fuel).
This is just an opinion based on what I have experienced.
