True Dual Photos
Are you asking me?
j/k
I was wondering since i think i'm going to copy your set up and i need to use me 3" slp cats and cut up my 3" y pipe.I did'nt want to use recducers everywhere.
Same X-pipe with Magnaflow 4x9 ovals. (Less loud, deep, smooth)
Neither setup offered me decent ground clearance (SLP LT's did not help, also the X-junction would scrape sometimes). I switched back to a Y-pipe and catback because I was tired of the low clearance.
kilr12 - 2.5" is more than enough size to handle the power I have / will have. There was no need for 3" which would cost more and give less clearance.
Two quick ???
What are your tips mounted to, the frame or bumper?
How much are you lowered? What springs....
BTW looks sick man...
John
Thanks.
Tips are mounted to the frame. And the car is lowered with the SLP Bilstein suspension, which comes with (specifically tuned for the setup) Eibach springs. Since I ordered the car with the suspension on it, I am not sure how much it lowered it. But I believe its about a 1" drop.
Brian
Put in a picture or two with a description of your setup. (pipe diameter, mufflers, cats, headers, etc.)
Also some ground clearance pictures would be nice
Thanks
