People Who Have True Duals Does The Exhaust Smell Burn Your Eyes When Your In The Car
Eyes burned a little bit till I got used to it but I went ahead and put cats back on caause fumes too much. Athough it didn't get rid of all the fumes, like 1fastbird says but it did get rid of just ebough to stop me from coughing
6600 rpm clutch dump of death Administrator
Originally Posted by HorsePowerKing
maybe i have just gotten used to it though
Originally Posted by LS69TA
The smell doesn't bother me, but my wife doesn't care for it at all.
You're singing my song brother.. i have recently ran my Lanes True Duals out the back.. no more vibration, only an awesome sounding 4th gen.
My wife likes it a little better.. @least i don't wake up the neighborhood.. just the neighbors..
Originally Posted by LC1
The duals rattle beecause of the rear mounting points...
I removed the stock carpet, and i'm getting a stupidly loud metal shake rattle...
removed the duals.. gone...
basically the part where they bolt on is too thin.. and shakes too much.. gotta figure another way to mount them...
Originally Posted by LowETz
Pull the seats(if you've still got'em)and carpet. Use a punch from under the car and pierce the metal. Drill a hole(or two), run the bolts through the holes from inside.... tack weld the bolt heads and reassemble w/lock washers. Good to go.
the metal only shakes between 1500 and 2000rpm... no more.. thats odd...
I will try to put more rubber between the duals and the mounting points or something...
#33
Sold The Fun Stuff :(
I have TDs dumped and a cam. Even before the tune I rarely noticed any smell, and it was only if you're outside the car standing directly behind it and the wind is blowing just right. In the car at a stoplight with the windows down and the t-tops out I still dont smell it.
#34
Originally Posted by GTObsessor
Well.. I'll have em installed in the not-so-distant future but that sounds more like a tuning problem?
Do TD's really make the car rumble that much? Is the idle vibration increased that much? I'd really like a rumbly car... thought the only way I could do that would be to get a cam with at least 112 LSA... but that's a lil later on
