What is this part called?
Old Nov 30, 2005 | 02:09 PM
hardcorebob's Avatar
Default What is this part called?
I'm about to install QTP 1 3/4 SS headers and a QTP dual cutout ORYP. I know all about the banging pipe YP on the passenger floorboard, what is the part called that you can mount to it so it doesn't hit the bottom of the car? ORYP bracket? Bushing?
I am buying all the needed "little" parts right now and wanted to get the exact name of it so I could shop for prices. If anyone knows what I'm talking about and has a link, post it please!
Old Nov 30, 2005 | 02:11 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Mufflex bump stop hanger, available at Thunder Racing.
Old Nov 30, 2005 | 02:14 PM
!LS1 11 Second Club
Also, have patience with your QTP dual elect. cutout ORY. It's a puzzle. Another note; the cone reducer from the 4" Merge collector will still probably slip over your I-pipe too loosely, so the clamp provided probably will not provide a good seal. Have that connection welded if you want a good, leakproof fit (just a few tips from when I installed mine).
Old Nov 30, 2005 | 02:26 PM
SouthFL- thanks for the product name and install tips! I do appreciate you helping me out like that and that's another reason why ls1tech.com is the shiznit! If you have any other suggestions, fire away.....
Old Nov 30, 2005 | 02:30 PM
!LS1 11 Second Club
Wiring the qtecs up thru the drain plug grommets under the seats is very convenient also. Just drill a hole/ or cut a slit in the grommet and you're good to go.
