Question before dropping the motor
Old Dec 1, 2005 | 10:28 AM
Camaroguy's Avatar
Default Question before dropping the motor
Everytime i dropped the motor out of my camaro i always let out the A/C. Not sure if this would work or if its a closed system, but if i just remove the whole ac compress from the motor and leave it in the car closed along with the condensor will the system remain closed if i just unbolt the Compressor from the motor? Or will it leak out as soon as you unbolt it?
Old Dec 1, 2005 | 12:04 PM
conan's Avatar
As long as you don't unbolt any of the lines with freon in them you'll be fine. Taking the compressor bolts off the engine block wont drain anything.
