Anybody cut the plastic on the ram air?
Old Dec 3, 2005 | 06:52 PM
Pavetim's Avatar
Default Anybody cut the plastic on the ram air?
The plastic part in the ram air hood that forces the air down anybody cut this out to allow more air in? And how would this effect the car in rain? Thanks guys
Old Dec 3, 2005 | 07:03 PM
Griswold's Avatar
I took out the back baffle but left in the front two. No problems in 5 years
Old Dec 4, 2005 | 12:31 AM
black01_WS6's Avatar
took all of them out. water can't go up. there is a thing called gravity. you will see some more top end power. the filter is going to get wet, but rip them bastards out.
Old Dec 4, 2005 | 12:36 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I removed mine on the WS6 shortly after I got the car. Then I installed a BG Ram Air kit to fully seal the hood scoops to the air box (keeping hot air from the engine bay out). Brain Greene (maker of BG systems) just recently stopped producing the system though, but you might be able to find them used.
Old Dec 4, 2005 | 07:00 PM
Pavetim's Avatar
So getting the filter wet won't matter, the engine won't suck the water in? I know water can't go up but if it gets in the ram air the water will go down.
