Pacesetters and TRue Duals installed
Old Dec 4, 2005 | 07:49 PM
BPLS1's Avatar
Talking Pacesetters and TRue Duals installed
yesterday i dropped my car off at my homies Pad to install my Pacesetter Ceramic coated Headers and TSP True duals. i couldnt help cause i was at work buyt needless to say it was a pain in the ***. at the end i drove it and it was Back firing Really Bad so i was kind mad but then i punched it and it sounded and felt Beautiful . the only thing that really bothers me is the contstant Backfiring, What could b my problems guys. Thanks
Old Dec 4, 2005 | 07:56 PM
SSpdDmon's Avatar
Check all connections for fuel and spark. A plug/wire might be loose or an O2 sensor may have been left unplugged.
Old Dec 4, 2005 | 07:59 PM
TRU-2GM's Avatar
My car did the same thing, and i just had to replace my O2 sims, i got extensions up front and just the plug in delete ones for the back, and it solved all my problems. They say if you drive it too long like that it messes up your timing. I am sure someone can help you out a little more than me on what you need, but mine was exactly like that, and I just got new sims for it and it ran great.
Old Dec 4, 2005 | 08:02 PM
TNMuscle's Avatar
probably the 02 sensors check them and if they look ok then replace them
Old Dec 4, 2005 | 08:09 PM
tim99ws6's Avatar
check 02's plugged in correctly, and Check for exhaust leaks!!
Old Dec 4, 2005 | 09:25 PM
SgtB's Avatar
yes double check all of your connections...you will probably find something.
It could if it starts triggering the knock sensors.
Old Dec 4, 2005 | 10:26 PM
Hambone 7's Avatar
Id say you have a burnt plug wire, happens alot when you first put headers on and havent quite tweaked the wire routing to keep them from getting burned.
Old Dec 5, 2005 | 12:13 PM
BPLS1's Avatar
actually one of my msd wires broke off in half when i pulled it off but i replaced it and it didnt solve the problem it must b something else. im going to check them all again, cause that constant backfiring is annoying the **** out of me
 Michael S. Palmer
Old Dec 5, 2005 | 02:34 PM
Camaro99SS's Avatar
He has an LS1, not an LT1.
Jason
Old Dec 5, 2005 | 11:56 PM
BadBowtie03's Avatar
Was the car warmed up????
Old Dec 6, 2005 | 02:33 AM
BPLS1's Avatar
update. after one day of driving the constant backfiring was driving me insane so i took it back to my homies and he had his scanner, well it turned out that i had a misfire in cylinder 4, and the drivers side 02 sensor was acting up we fixed the cylinder and i thought that no more codes would show up. there was one code left that wouldnt go away it was p449 it was it was coming from that evape square thing that connects to the EGR on top. still backfiring so i think i might need a new one
Old Dec 6, 2005 | 12:08 PM
BPLS1's Avatar
oh one more thing, what would b causing my ASR to turn off Randomly and stay off, and ABS INOP. im have constantly seen those codes since the LT Header Install
Old Dec 6, 2005 | 12:38 PM
tim99ws6's Avatar
check the connections at the rear brakes. I bet when you ripped off the stock atback, you hung it on one of the wires, and now it is turning off. usually this is the case.
