Bought used LS6 intake, Problems, Need Help
On the back of the intake, there is a smaller and a larger vacuum line "snout" if you know what I'm talking about. The larger one is broken off. Also, if you're looking straight on at the back of the intake, on the lower left where the entire circular sensor is, the seam between the circular sensor/vacuum area and the actual intake is cracked a bit.
I didn't know if these were common problems that can be damaged during installation/removal or shipping, or what possible solutions I have without scraping the intake and throwing $300+ down the drain. Thanks for any help.
As soon as I get this figured out I can buy the crossover tube and coolant plugs, and get an underdrive pulley, and I'll be set for the next round of mods.
OK, looks like the one connection is the MAP sensor, the small nipple is the vacuum line, and the larger one is for the brake booster. The brake booster is the one that is broken off (clean break, still have the piece that broke off), and in one small area around the MAP sensor there is a crack.
Just wanting to update with the correct info.
http://www.hobbylinc.com/prods/rgg.htm
With respect to the vacuum port that is broken. I doubt gluing this back without additional support will work for long. I do not know the diameter of this port, but try to find a copper or brass tube that will just tightly fit inside the port or around the port. Rough both surfaces (metal tubing as well, especially) with sandpaper, clean, and then epoxy the metal tubing half inside (or outside) the port piece on the intake and slide the broken piece of the port on (or in) the other half of the metal tubing using epoxy as well. Let dry at least two days. This way, the metal tubing takes the stress of the booster hose and any clamp. The metal tube will have to fit snug on or in the port. Just an idea.
Just to clarify, the metal tubing does not need to be longer than the original port, again it is just to take the stress off the joint where the port is glued back together. Hope this makes sense.
Kurt
www.autokraft.org
I coated most of the inside of an aluminum water pump housing with JB Weld after using the wrong pump and cavitating a hole in the housing. Two years later it was still perfect when I got around to putting in another housing.
Also, good leads on the metal tube idea and the site with the epoxies and plastic welder stuff on it. Thanks fellas.
