Changing Cutoff Switch To Conv. Switch
Old Dec 6, 2005 | 05:11 PM
LS1ROPER's Avatar
Default Changing Cutoff Switch To Conv. Switch
Can Anyone Give Me The Link That Shows The Wiring Diagram To Change The Qtp Elct. Exhaust Cutoff Switch To A Stock Convertible Switch.
Old Dec 7, 2005 | 09:40 AM
2001NBMZ28's Avatar
Found this - not sure if it's what your looking for.
www.ls1tech.com/forums/showthread.php?t=372207
Old Dec 7, 2005 | 10:07 AM
01 Red WS6's Avatar
THere use to be a write up on ls1.com. I'm not sure if it's still there though.
Old Dec 8, 2005 | 01:35 PM
2001NBMZ28's Avatar
A friend of mine gave me this today - excerpt from a thread on the old ls1.com in May 2003:
Use GM harness PN 15306189 - plugs into the back of the conv switch.
Pin B - Illumination
Pin C - Illumination ground
Pin H - Ground
Pin D - Ground
Pin F - Ignition
Pin E - Cut out motor
Pin A - Cut out motor
Don't know if this will help but thought I'd post it.
Old Dec 8, 2005 | 05:39 PM
LS1ROPER's Avatar
Thanks For All The Info., Just What I Needed.will Tackle That Project This Weekend..
Old Dec 8, 2005 | 06:05 PM
SUX2BU's Avatar
i had mine like that and DAMN! thats an expensive switch and plug.
