Running to cold?
Old Dec 9, 2005 | 04:07 AM
BULLET99Z28's Avatar
Default Running to cold?
Mods are in the sig, heres my ?. I have the 160tstat, me and a buddy went in w/ hptuner, turned off the cags,air,egr and rear o2's. we also set the fan tenmps one at 175 and 184-5 i think. is this to cold, could I be running 2 rich, wspecially with the long tubes, just curious if I should let her warm up a few degrees more to make max power with my setup. thanx for any advice yall.
Old Dec 9, 2005 | 02:50 PM
akZ28's Avatar
no you dont want it running hotter, the cooler the engine stays the more power it will produce.
Old Dec 9, 2005 | 06:41 PM
mrr23's Avatar
there's a point where being too cool hurts the power as well.
http://www.vincihighperformance.com/...20PAGE%20.HTML
read the bottom.
Old Dec 9, 2005 | 06:52 PM
well yes, the cooler the temp, the more enrichment the computer gives-ie more fuel and spark advance. but like the vinci page explains, the motor and its tolerances are also affected by the temp, thus affecting how the motor runs, just wondering if this is to cold, should i set the temps 5-10 degrees warmer, I am in texas, so its no supr cold very often,long hot summrs,etc.
Old Dec 9, 2005 | 06:56 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
IMO, 175 is too cold for these motors. Both my (mostly) stock LS1 and modded LS1 have always seemed to run their best in the 190-200 range.
Old Dec 9, 2005 | 10:25 PM
TJ's Avatar
TJ
ditto.
with a cool down at the track, my car is almost 2 tenths off(slower) when ran at 160-175 as opposed to 190~ish.
i vote hot!
Old Dec 10, 2005 | 06:59 PM
Dynoed the car at RPM today, they said to leave it like it is, I have no knock and no detonation. Plus the car pulled really well, and its not to rich, the factrory tune ran awesome, they said the only thing they would cahnge is mayybe a little more timing since I have no cats. Plus the air fuel ratio was damn near a flat line across the whole pull. 332hpand 342 tq, not bad!
