ASP Pulley
Old Dec 12, 2005 | 11:10 AM
DarkHawkLS1's Avatar
Default ASP Pulley
http://www.lmperformance.com/599/
Does this deal come with a new belt? If not, where can I get one. I need the the crank belt, and A/C belt.
I can just get another crank bolt from a dealership, correct?
Old Dec 12, 2005 | 12:04 PM
8GTOKLR's Avatar
Since you have an Auto you'll need alt pully too...check out page for more info
http://www.ws6project.com/user_stor/...d71c468125af1a
Old Dec 12, 2005 | 12:10 PM
Z28LS1camaroguy's Avatar
go to texas speed and get the powerbond pulley it comes with both belts, also i think they sell the crank bolt, if not you can get it from gmpartdirect.com they sell them.
Old Dec 12, 2005 | 12:22 PM
LS1-450's Avatar
Yes, the bolt can be purchased from a local dealership. I used Good-Year Gatorback belts #4040377 for the AC & #4060760 for the crank, alternator, PS pump. My alternator pulley is 2-1/4" diameter. Don't know if the stock diameter is the same. Would check the alternator diameter prior to belt purchase.
Old Dec 12, 2005 | 01:42 PM
billscamaros's Avatar
"Since you have an Auto you'll need alt pully too"
i have an ASP underdrive pulley set also ... crank and alternator pulleys ... for my 99 z28 w/ 6 speed.
are you saying that i don't need the alternator pulley since i've got the manual trans ??? i don't recall reading that anywhere in the instructions.
Old Dec 12, 2005 | 02:10 PM
8GTOKLR's Avatar
Its on that link....M6 cars need a alt pully if you have a high output stero unit and or lights etc..
Old Dec 12, 2005 | 02:11 PM
you2slo's Avatar
The alternator pulley isn't required but you may have charging issues if you have a lot of electronics draining the charging system.
