wierd valve cover vent tube question
Old Dec 13, 2005 | 10:26 PM
DreamState23x's Avatar
Default wierd valve cover vent tube question
I changed over to a ported ls6 manifold and ported bbk 80mm T/B. I had a loud squeal coming from inside the motor after install. I found that as soon as I unplug this vent tube(the one going from the valve cover to the T/B) from the T/B the squeal stops. Also noticed that the tube has suction and the tube on the TB has suction, so they are fighting each other. After about5 second of being unpluged the suction on the tube going to the valve cover dies off. Any ideas??
Old Dec 13, 2005 | 10:35 PM
kpowr82's Avatar
are you talking about where the pcv valve goes?
Old Dec 13, 2005 | 10:44 PM
SUX2BU's Avatar
the tube coming out of the throttle body should not have vacum (suction). only the one coming out of the intake should have vacum.
Old Dec 14, 2005 | 01:14 AM
Hmm.. well that is wierd, mine has a lot of vacum.
kpowr82: No the one on the T/B not the manifold. but still on the same side. But not the coolant one either.
