Need C.A.R.B Legal Cats
I'm Having A Problem With Using Stock Cats On A 98 Ls1 Engine. They Obviously Are Restrictive When Using A Supercharger And Nitrous. What Is My Alternative. Need To Stay C.A.R.B Legal.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
if you want them to still be legal they have to remain in the same position in which they were installed from the factory. I know Random Technonlogy has a set that replace stock cats in the same position.
I called CARB about two years ago and as of then there were no CARB certified replacement cats. That being said, probably 98% of smog techs won't be able to tell the difference visually, as long as they pass the sniffer.
I talked to Random Technologies and they do make a OBDII converter but it is not a California OBDII legal. In California that is the only issue. I am going to call Magnaflow and see how far out they are if they are indeed making them
