extending the o2
Old Dec 18, 2005 | 12:11 AM
BlutVonSchwachen's Avatar
Default extending the o2
i just bought some lts and with them they sent some wire to extend the 02 sensors. Just wondering if that will be fine to do that or should I look at getting the extensions?
Old Dec 18, 2005 | 02:08 AM
Lithium's Avatar
SSU's Drunk Typing Whore
I am sure that they would work...how long? I dont know.
I just laughed at the ones I got sent and bought some extentions.
Old Dec 18, 2005 | 11:50 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I opted to use actual prefabbed O2 extensions. Splicing the wires just seemed like a bad idea to me.
Old Dec 18, 2005 | 11:52 AM
227Hawk's Avatar
Another vote to just getting extensions.
Old Dec 18, 2005 | 11:53 AM
SgtB's Avatar
Buy the prefabbed extensions. It is much easier to just plug them in.
Old Dec 18, 2005 | 12:18 PM
Splicing into them isn't very complicated either. Probally just take me an extra 2 minutes or so, but I was just wondering if the reliability over the prefabbed connectors are worth the extra money.
I have Pacesetter LT's, how long of an extension should I look at getting? Also, can anyone recommend a good sponser to buy a installation kit from? (metal gaskets, bolts, etc).
Old Dec 18, 2005 | 01:39 PM
SgtB's Avatar
reuse your stock manifiold bolts...they will work just fine.
Call Speed Inc...They will set you up with gaskets and extensions.
Old Dec 18, 2005 | 03:14 PM
TheBlurLS1's Avatar
That's what she said...
You can reuse the factory gaskets (they are steel) and bolts. I would DEFINATLY get the extensions, most people go with 2 24" extensions. I used a 12" and a 24" and they worked awesome.
Old Dec 18, 2005 | 09:36 PM
So all the gaskets should be fine to use with 103xxx miles on them?
Old Dec 18, 2005 | 10:46 PM
TheBlurLS1's Avatar
Mine were fine at 90k, new ones at the dealership are about 14 bux a piece if i remember correctly. I also think that each side is different too, they are labled on the gasket itself
Old Dec 18, 2005 | 10:48 PM
CRL 01 SS's Avatar
Get the prefabbed o2 extensions. When you get into splicing wires it's just one more thing that you have to worry about. The cost of the o2 extensions are worth the peace of mind.
Old Dec 18, 2005 | 11:51 PM
ibanez7's Avatar
just finished installing hooker lts on my 01 z28 with 80,000 miles.
I resused the gaskets and bolts, but I did add lock washers
also to make the job easier I removed the coil packs, and valve covers, and steering shaft. (powdercoated the valve covers too)
if you remove the coil pack an easy trick to do that I did was:
passenger side coil pack rear mounting stud is a pain, huge pain in the *** to get in and out, so before install to make this process easier and quick.
I screwed the autostud back in the valve almost all the way down, then I took the coil pack and cut the rear mounting hole into a "U" shape, allowing me to slide the coil pack under the rear stud. Which now all i have to do is twist the rear stud a few times(loosen or tighten) saving my knuckles and time, for quicker install and removal of the coil pack.
also, everything is 10mm and 8mm.
if your removing the cats, ditch the air pump too!
Old Dec 19, 2005 | 08:03 AM
jimmyblue's Avatar
Moderator
Put the money you would have spent on extensions,
toward a set of Corvette rear O2 sensors. Your tune
will thank you for it.
Corvette Rear O2 Sensors:
Bosch 13111
Denso DEN 234-4087
Old Dec 19, 2005 | 09:31 AM
ibanez7's Avatar
Bosch 13111
Denso DEN 234-4087
I've never heard of that before! how does rear vette o2 sensor work well for front fbody o2 sensors?
Old Dec 19, 2005 | 11:39 AM
TheBlurLS1's Avatar
Bosch 13111
Denso DEN 234-4087
Explain-e-ate youself!
Old Dec 19, 2005 | 11:43 AM
jimmyblue's Avatar
Moderator
Headers cool the exhaust gas more than stock
logs. The stock F-body O2s have wimpy heaters
because they count on the heat, being close-in.
'Vette rears have long cables, plug right up and
run more heater wattage, making for more reliable
readings and less false-fuel-trimming from being
too cold.
Old Dec 19, 2005 | 02:02 PM
ibanez7's Avatar
too cold.
so it is better for tuning (ls1 edit), and its a more accurate read for your fbody computer!
Old Dec 19, 2005 | 04:19 PM
Dont suppose any sponsers sell those... dont really have time to go to any dealerships between work and school these days.
Which brand would be recommended, denso or bosch?
Old Dec 20, 2005 | 09:10 PM
Bosch 13111
Denso DEN 234-4087
So I gave me parts guy a call, $70 for one brand, $140 for the other...each. That's quite a lot more than extensions. Will the extra wattage really make a big enough difference to justify such pricing?
Old Dec 20, 2005 | 10:52 PM
krexken's Avatar
Soldering gun+heat shrink=cheap, very effective and reliable.
