Why are you still stock internal?
It's just a matter of time... I've done most bolt-ons already, The 4.10's are on order; Sub-frame/AdjTorqueArm/CtrlArms will be Feb. Then there's the new clutch... At some point this summer (I bought the car in 2000!) I'll finally get to Heads(AFR 205's)/Cam(F13 112+4) swap. I'm planning to replace the lifters (Stock? or Comp R's?) and rod bolts (Katech). I've got almost 90K, and I've beat on her pretty good on a regular basis. If it breaks after that, I kick myself in the butt, and buy a LS7 crate engine on credit...
If I can install my cam/springs/pushrods/timing chain/oil pump by myself in my garage using www.ls1how.com instructions in 25-35* air, anybody with a inkling of mechanical ability can do the same.
But in May i'm moving closer to my job and then its on like donkey kong! T rex here i come! I can't wait to hear this exhaust with a big *** lopey cam.
You'd be surprised. After the heads and cam my car gets nearly the same gas mileage as it did stock internals. Basically it gets a little less mpg in city, slow driving. On the highway it's nearly identical.
I'm also currently paying for my wedding this may and have already spent WAY too much $$$ on my car after i said i was done till after the wedding. What with blowing my motor, then trashing my tranny.
There went $1,300 that could have paid for my honeymoon.
Hal springs in front, V6 springs in rear
adj chromoly rod end LCA
LCA relocation brackets
BMR trak pak TA
no front sway bar
stock swaybar in back
mild steel tubular K member, A arms
5 point chromoly weld in rollbar
BMR square subframe conn.
I think thats it.I havent really messed with anything though, i haven't even messed with the shocks settings to try to get beter 60's. just threw them on at whatever my friend had them at.
87 octane is half the reason it blew up, the other half is the JUNK FAST 90mm TB.
**** A FAST 90mm tb!
