Car Idles high when cold outside but engine is warm
I recently removed my AIR system and pump and I do have a SES light for this, but I wouldn't think it would have an impact, but maybe it does...? For what it's worth, I have a stock cam, but the throttle body is ported (but not too close to the blade). Other than that my car has just intake and exhaust mods (see sig). Can the IAC valve get fouled and get sluggish and stick open? Any experience or suggestions on what causes a warm engine to idle high in cold weather and how to fix it...?
1. Take out the IAC motor, and make sure it is clean. This is cheap and easy to do.
2. Since you removed the AIR system, make sure you plugged up EVERYTHING...especially the **** behind the intake manifold. There are a couple random hoses that need to be plugged that are small and can easily be overlooked. Vacuum leaks suck (literally).
3. If none of that works, it is most likely due to your tune. I had problems with my idle hanging after a ported throttle body, and after educating myself with HPTuners, I figured out that my Base Running Airflow was too high. Your idle trims only work when your car is sitting still in addition to idling (yes, it references your vehicle's speed too). There are long term idle trims, and short term idle trims. Any time your car isn't idling or moving, the STITs go to zero. The LTITs retain their value so it knows where to go when it returns to idle, but it doesn't matter if you are still rolling or you come to a full stop. So if you are coasting to a stop, and your LTITs are telling your IAC to add more air, and it is too much air, it can't correct for it until you come to a complete stop and the STITs come back in action (since they are the only things that can change the LTITs -> LTITs = The average of the STITs).
Make sense?
Make sense?
As for #3, that is exactly what happens / what it does! Now that you gave me some insight to the logic for the PCM to control the idle, the pattern is obvious. I had started to notice that I could only get the car to idle after I let it sit without moving for 5-10 seconds. I thought it was just a strange coincidence - apparently not! I have a RWTD tune, so I'll add this to my list of things to get done on an update I just requested.
Headed to Tampa today for Christmas so I won't mess with it until next week.
Thanks...
Not much is vacuum driven on the car, if you removed the air you shouuld be fine the air only sends cold air to the cats. I removed mine w/o any issues.
Back to the TPS, mine went out and caused the throttle to be very erratic. I could sit at a stop sign or push in the clutch when i'm rolling at 40mph and the rpm would surge, like a vacuum leak on a carbed car. Also my idle sat between 1100 and 1300. The gm dealer said it was the IAC, I checked it out and it was fine. I bought a new TPS for $30.00 at autozone and the car runs fine now!!
