which is better??
Old Dec 23, 2005 | 09:11 PM
Magnet's Avatar
Default which is better??
i have found two techniques when porting my own tb, there is the cut one side off of the middle part as shown in picture 1 and 2 OR grinding down between the screws as in picture 3 and 4. would it be ok to cut off the front part and then grind between the back part??
PIC 1
PIC 2
PIC 3
PIC 4
Old Dec 23, 2005 | 09:52 PM
Magnet's Avatar
im sure someone has an opinion...im jsut worried if i cut the top off and then also grind between the screws on the back it may not have enough strength?? i dunno
Old Dec 24, 2005 | 05:41 PM
ls2 bait's Avatar
my bo white tb has the cut top and the bottom left alone. looks great too me and im sure its not going to cause enough of a restriction to cause an issue.
Old Dec 24, 2005 | 06:07 PM
Magnet's Avatar
yea thats what im doing, im in the process of porting it myself, i was goign to get a bo white tb , but i want to know how to do it. hey by the way i installed my pacesetters this friday with my dad.
Old Dec 24, 2005 | 06:17 PM
ls2 bait's Avatar
cool how was it? did u get it tuned or just throwing a engine code? did u go with the ory? did u feel a big diff? u gotta let me know because ill be throwing mine in prob in like 2 weeks. as soon as i procur an ls6 intake.
Old Dec 24, 2005 | 10:34 PM
Magnet's Avatar
well actually i havent driven it yet its still way up in the air im waiting for my 02 extensions and sims to come in, hopefully i wont be throwing any codes, but no its not getting tuned until i get a cam....somtime in the future lol
Old Dec 25, 2005 | 06:11 PM
Bo White's Avatar
Cablebandit is running a twin turbo set up on one of my TBs and its good to go. I have also done testing of my own on how durable the half shaft mod is and let me put it to ya this way- I had to bow up on it to break it with my hands and Ive gotta grip good enough for 150 lbs or better. One thing Ive always done though is use #6 washers under the screws to reinforce them since the head design is tapered to fit the front half of the shaft and since that is gone now I use them to spread the load out more evenly . Also another tip is to use Loctite 262 on the threads when you assemble it back together .
Old Dec 25, 2005 | 06:51 PM
Magnet's Avatar
what do you think about porting the back side of the shaft and also cutting the front half off??
 Michael S. Palmer
Old Dec 25, 2005 | 07:31 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I found this to be something that is hard to pass up when one of mine was half backed out when I swapped TB's.
Old Dec 25, 2005 | 08:19 PM
Bo White's Avatar
Only a flowbench could see a difference with doin that(porting back part of the shaft after halfshaft), and maybe not even enough to speak of.
Old Dec 25, 2005 | 09:04 PM
MadBill's Avatar
Speaking of flowbenches, with all these porting threads and all the various availableTB bore sizes, is there flow data to be had for any of them?
Old Dec 25, 2005 | 10:40 PM
Bo White's Avatar
Not yet. JRP has a couple of ported TBs that he was going to have tested but I think it was put on a back burner so he could get his ride back going again(one of them is one of mine).
