ordering headers and y pipe soon, few ?s
should i have a cutout on each side directly after the collecters, or just 1 cutout on the y pipe?
how will this set up be regaurding ground clearence?
i have a slp loudmouth and well be getting a bullet muffler in place...what type, kind, size
thats all i can think of now, thanks for your help
yeah ive read that its gonna be loud as ***** so i plan on getting a borla bullet in place of the slp, i just dont know what kind to get
This is from JRP's sticky -
Loudmouth: LM is a love/hate exhaust, it sounds great on stock manifolds with few bolts on's. When you start adding LT's and ORY's it shows its ugly side. LM + ORY + LT = rasp and drone. Try and listen to various LM setups in person to know what your getting into. Time after time people get LM and end up swapping it out since they get tired of its annoyances. To reduce the rasp and drone you have a few options; install some cats, replace the resonator with a real muffler, or install a 12-18" dynomax bullet. This setup is referred to Dynomouth; Borlamouth is of the same concept but with Borla xr-1 mufflers.
If you go in a polish them up every once in a while they will last you a long time. They are never going to rust through, its just surface rust. They will definitely out last the life of your car.
I am glad that I went with coated Pacesetter's. Very little rust after almost a year...just clean them up every now and then. Also stay out of the rain/snow!!!! That will really rust them up. If thats a concern then you need to go with stainless steel.
Why not get a quiet cat back and a cut out so you can have the best of both worlds?
now as far as the cut out...i thought the closer to the headers the better?...should it go right after the y pipe?
