Installed Wires an & Trans Mount..?
Old Dec 24, 2005 | 07:01 PM
Kyle C's Avatar
Default Installed Wires an & Trans Mount..?
Just installed MSD wires and Energy Suspension trans mount today. I wasn't expecting to feel so much engine vibration after changing the trans mount. I assume that if there were some kind of miss from a bad connection with one of the wires I would have an engine code. I've driven 100+ miles with no codes, is it normal to have alot more engine/drivetrain noise transmitted to the chasis with these mounts? Should I look at anything else or just get used to it?
Old Dec 24, 2005 | 10:04 PM
Ferocity02's Avatar
The poly trans mount will transmit more vibrations into the car. I noticed a lot more clunks and bangs with mine. I've gotten used to it though, but I still have to explain to my passengers what the noises are
Old Dec 24, 2005 | 10:42 PM
Juiced2000SS's Avatar
I have one and didn't notice anything like that, that's weird.
Old Dec 25, 2005 | 01:11 AM
REDWS6ROCKET's Avatar
me either. the trans mount made a huge difference in my old 6 speed cars. but yeh check your wire connections. i hear the msds have a connection problem every now and then,
Old Dec 25, 2005 | 01:13 AM
TheBlurLS1's Avatar
That's what she said...
I noticed a little vibration while getting up to speed with my poly tranny mount. You will never notice it again in about a week. I LOVE how my shifter never moves up and down anymore, plus the wheel hop seemed to decrease quite a bit.
Throw some poly motor mounts in there! They actually REDUCE vibrations for most people and stiffen things up really well
Old Dec 25, 2005 | 10:29 PM
BULLET99Z28's Avatar
POLY mount is sweet.
Old Dec 25, 2005 | 10:37 PM
Bo White's Avatar
Noticing that is very common, sold many of em when I worked at a speed shop. I noticed it as well when I put mine on but like was said ealier it wont be a big deal after a while . Theres always some kinda trade off somewere on mods, its a Newtons law thing I guess lol.
Old Dec 26, 2005 | 08:37 AM
TAQuickness's Avatar
I haven't installed my poly trans mount yet, but am wondering if the vibrations you are feeling are from stock motor mounts combined with the stiffer trans mount.
Old Dec 26, 2005 | 08:52 AM
777's Avatar
777
Check the wires again. One click for the plug, and two clicks for the coils. I left a wire completly off once and there was no code, so it is very possible that that is your problem.
Old Dec 26, 2005 | 09:28 AM
Kyle C's Avatar
Check all but the dreaded #8. I'll do that next time I'm on the lift. I've run a tank through it, the mileage is normal so I suspect #8 is OK as well. While on the lift I think I'll remove the mount, grind off the preload humps and re-install without the preload plate. This should drop the transmission down closer to its original location and hopefully no preload will decrease some of the vibration?
Old Dec 26, 2005 | 09:29 AM
Bo White's Avatar
One quick way to check for a dead cylinder is to get a sqirt bottle and fill it with water and spray each header tube with the engine runnin and if you have a dead cylinder it will be very noticeable this way.
Old Dec 26, 2005 | 09:33 AM
Bo White's Avatar
I wouldnt worry about the preload. It will get better harshness wise with driving- they designed the preload for a reason. I have had a couple cars with the ES mount and noticed it go away after a while, may have been in my head but it went away lol.
