pulley question
Old Dec 25, 2005 | 03:13 PM
hardtopz28's Avatar
Default pulley question
i have a asp pulley do i need diff belts to put this on or will the stock ones work
Old Dec 25, 2005 | 06:12 PM
chrs1313's Avatar
different belts the pulley is smaller so the belts will be too big, look on the asp website they have the part numbers
Old Dec 25, 2005 | 06:34 PM
2_wacko's Avatar
You will need a different bolt then stock also.
Old Dec 25, 2005 | 07:50 PM
Tally TransAm's Avatar
not a different bolt just a new stock bolt
Old Dec 25, 2005 | 08:12 PM
777's Avatar
777
Or an asp bolt. You will need a smaller serpentine belt and a/c belt. You will also need a pulley puller and a big breaker bar. A 1/2" drive torque wrench. I think it's a 24mm bolt. The asp pulley bolt is a 27mm 12 point IIRC.
Old Dec 26, 2005 | 08:26 PM
hardtopz28's Avatar
thanks for all the help
