Air Pump Removal Question
Old Dec 30, 2005 | 05:38 PM
FRCBobby's Avatar
Default Air Pump Removal Question
I just removed the air pump from my 2000 Corvette. What do I need to do with the line that is like a vacuum line attached right at the air pump?
Old Dec 30, 2005 | 08:30 PM
GTObsessor's Avatar
bump.
Old Dec 30, 2005 | 10:10 PM
2000 TAWS6's Avatar
Not sure, the vacuum line on my WS-6 was at the back of the intake manifold, which I plugged and secured to something back there.
The only lines attached to the pump were the large AIR lines, which are in a box in the garage now along with all the egr stuff.
Old Dec 30, 2005 | 10:22 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Same here. If it's a tiny vacuum hose, then it's probably the same hose us f-body guys have at the back of the intake manifold. Yours is probably just routed a different way. Does is happen to run through a part of the AIR system that looks like an older EGR valve?
I plugged my vacuum line with a screw lathered in thread locker.
Old Dec 30, 2005 | 10:34 PM
chpmnsws6's Avatar
pull the line out from the back of the intake and find a new connection for back there. if i recall (its been a few years now), you can use all stock connections without plugging any up (somehow)
Old Dec 31, 2005 | 02:09 AM
FRCBobby's Avatar
Yeah it is not on the air pump itself, it is on what looks like an older EGR valve. So should I just plug it off or what?
Old Dec 31, 2005 | 07:59 AM
2000 TAWS6's Avatar
Yes, plug in securely, and tie it down to something so it doesn't flop around.
Old Dec 31, 2005 | 09:11 AM
FRCBobby's Avatar
Thanks, going to do that now.
