Pacesetter long tubes and tsp ory pipe ????
http://nick.vettextc.net/Dynosheet.pdf
It's running a little rich and hopefully should pick up a few more hp with a new tune. I was told my numbers would have been a little higher before the stall converter which supposedly costs a few hp on the dyno.
I think most guys see about a 20rwhp gain with LT's and no cats.
With the LT's and ORY only my et dropped 4 tenths and I gained 3 mph
in the 1/4 mile.
Here's some pics of the headers and install.
http://nick.vettextc.net/Headers/
http://nick.vettextc.net/Header%20Install/
Good luck with the TSP ORY, I had a difficult time getting it lined up perfectly and had some banging issues prior to getting it in the right way. I think quite a few others had the same problem but it is a good piece once you get it in there correctly. Before you install the TSP ORY grind out the inside of the "Y" piece that connects to the cat back like I did.
http://nick.vettextc.net/Ypipe/TSPORY1.jpg
The first picture was taken shortly after I started grinding:
After:
At the time I put the headers in my car was lowered (Eibach Pro kit).
This is how much ground clearance I was left with after the install:
http://nick.vettextc.net/Ypipe/TSPORYclr.jpg
lowered with stock manifolds & cats:
http://nick.vettextc.net/Ypipe/OEMYclr.jpg
I'd pick up a set of GM gaskets and some 24" o2 extenders, also o2 sims or a tune.
in the 1/4 mile.
After:
Do you think you could PM me your phone number so that way when i get mine if i have any other technical issues i can just give you a call ?
Nic
