Pacesetter long tubes and tsp ory pipe ????
Thank you !
however the tsp ory was a different story (but that is because one of the pieces they sent me was a piece from the x pipe instead of the y)
also i had awesome ground clearance with my pacesetters but the TSP OFY with cats welded in sucks for ground clearance
but its prolly my fault, because of the cats i used, catco 3 in 3 out cats which are a full sized HI-Flow cat
Heres the pic (oh and i know the heatshield is supposed to be on top, bad exhaust shop=people not paying attention to their work)
I was reading in the sticky section on this section about installing headers.
I have a few more questions.
1) Does the TSP ory pipe have crushed sections on it for clearance like the one in the sticky section does?
2) Do the new stlye pacesetter hit the k member ?
3) do you have to buy 02 extensions with long tubes ?
4)how do you know where to cut the i pipe at for the new y pipe to fit ?
5) should i have them welded in or just use the band clamps ?
Thanks guys !
1) NOPE, the TSP Y doesn't have the crushed section
2)NOPE, i didn't do any fabing with my pacesetters, im 18 and my buddy is 17 and with NO EXPERENCE we put my LT's on useing ramps in about 3 hours and 15 minutes
3)YEP, for the front 02's but u can just live with the Check engine light on for the back ones(wont make your car run diff)....or get the code deleted, no biggy
4)the I pipe should fit perfect to the new Y without any fabing or anything
5)i didn't weld ANYthing except for welding the cats onto the Y pipe
that should answer your questions
But im tellin you man...LT's are the way to go if u are wanting to make big power, they are a HUGE gain over stock manifolds and the sound is amazing....and i wouldn't go with anything other than pacesetters(but thats just me) for the price they are hard to beat...mine are about 6 or 7 months old and my car is always exposed to the weather and they STILL look like the day i got em
