where do you put the oil temp sensor?
Old Jan 4, 2006 | 09:47 AM
SUTTERERMAN85's Avatar
Default where do you put the oil temp sensor?
since search is broke i was wondering where everyone is putting the sensor? and if i need any adapter fittings and such. thanks in advance. oh yea its on my 99 Z
Old Jan 4, 2006 | 10:00 AM
MrDude_1's Avatar
im not sure myself, but i can help you search the board.. you can use google to search it two ways.
1st way is to goto http://toolbar.google.com get the google toolbar, then you can just type what you want in, and click search this site... like the pic i made below has.
2nd way is to goto google.com and type in:
site:www.ls1tech.com whatever im searching for
the "site:www.ls1tech.com" part tells google to only look on LS1tech... the part in italics is what you're looking for, in your case its "oil temp sensor location"
so you would type in:
site:www.ls1tech.com oil temp sensor location
on google.
hope this helps until brains gets the search feature fixed.
Old Jan 4, 2006 | 10:39 AM
well i will try that them i guess. thanks
