Header install question
02 sims arent required, but if you are deleating the cats, you will throw a code, causing your SES light to come on. If you don't want that (no harm to your car at all, will still perform normally), then you can get 02 sims. Another option, get them tuned out (Usually around 40 bucks I beleive).
Just remember because they are long tubes, you also need o2 extensions, and you should be set.
