OK to run a catch can like this?
Old Jan 10, 2006 | 10:28 AM
lowchevy2go's Avatar
Default OK to run a catch can like this?
I got rid of the pcv and ran all 3 lines from the valve covers to a catch that i put in the compartmant under my battery in my ws6. Is this ok to run all 3 lines to the can? do i need to just use a vent on the driverside one?
Old Jan 10, 2006 | 10:54 AM
MeentSS02's Avatar
Kleeborp the Moderator™
You should be fine...just make sure that the fresh air line (the one from the passenger side valve cover to the throttle body) doesn't actually return to the throttle body (just make sure you put a vacuum cap over the nipple on the TB).
Old Jan 11, 2006 | 01:40 AM
should i run line from the catchcan to the intake to draw a vacuum on the can? Or will it vent through the filter on the can properly?
Old Jan 11, 2006 | 01:45 AM
rg42284's Avatar
Sorry to highjack your thread, but what is the proper way to run a catch can? From searching thru the site there has been 2 different ways.
I will be running a greddy 9mm unit. What is the proper way to install it? Pics would be great
Old Jan 11, 2006 | 08:50 AM
weestro's Avatar
^^ Pics: https://ls1tech.com/forums/generation-iii-external-engine/428410-pics-greddy-catch-can-install-56k.html
Old Jan 11, 2006 | 12:01 PM
MeentSS02's Avatar
Yes...run the line from the top of the can to the intake to draw a vacuum.
Old Jan 12, 2006 | 01:32 AM
but its vented through a filter on top of the can, wont this defeat the purpose of having a vacuum? It will be just sucking air from the atmosphere and nothing from the motor.
Old Jan 12, 2006 | 02:54 AM
BOONE's Avatar
Yes you would need a sealed unit, drawing from the intake.
Old Jan 12, 2006 | 07:48 AM
MeentSS02's Avatar
What kinda catch can are we talking about here?
Old Jan 13, 2006 | 12:35 AM
oil catch can, summit racing
