DIY cooling fan switch
Old Jan 10, 2006 | 02:44 PM
DougsfastZ's Avatar
Default DIY cooling fan switch
I'm not buying an SLP switch for $80, so I'd like to do my own. I'd like low/high/pcm with led capibilities. I just searched and came up with old threads with a ton of dead links.
Any good write ups out there?
Doug D
Old Jan 10, 2006 | 06:52 PM
krexken's Avatar
Try a search on Google and see what you come up with. I think that's where I found it before. It's pretty easy to do much more enjoyable than spending $80 to plug one in.
Old Jan 10, 2006 | 09:35 PM
tc3's Avatar
tc3
regardless of what setting the switch is on the computer will always have control over the fans, just fliping the switch will send false signal to the computer to turn the fans on... or the other way around... either way you get the point...
here is the guide for the switch
you MUST also READ POST# 10 here
Old Jan 11, 2006 | 01:45 PM
WILWAXU's Avatar
IMO, the SLP switch is worth the $$. Of course, it was only $59 when I bought mine
