electrical problem at WOT
1. Do I have a short some where?
2. Could my WOT switch for be grounding out of something causing this problem?
Any suggestion would help.
I have seen engine twist due to loose or broken motor mounts cause a disconnect where fusable links attach to the starter.
I would check out the wires on the starter and any ground straps connected to the engine.
