What size O2 extentions with QTP headers?
Old Jan 7, 2006 | 11:09 PM
BackinBlack02SS's Avatar
Default What size O2 extentions with QTP headers?
What size O2 extentions is everyone using with their QTP headers? On QTP's website, it says you need 2, 24" extentions, but some people say they are too long. What works best?
Old Jan 7, 2006 | 11:18 PM
WS6store.com's Avatar
LS1TECH.com Sponsor
A 12" on the passenger side and a 24" on the drivers side is usually sufficient. However, beings QTP headers are slightly longer than others, and they have it on their site, I would recommend the 24/24 extensions.
Old Jan 7, 2006 | 11:53 PM
Zymosis's Avatar
Word, with my qtp I just got equal lengh (24 inch), and it worked perfectly. They were a little long, but I don't think 12 would have sufficed.
Old Jan 8, 2006 | 08:50 AM
slow trap's Avatar
get the 24" and some zip ties.
Old Jan 8, 2006 | 09:14 AM
jimmyblue's Avatar
Moderator
Put the money toward a pair of 'vette rear O2 sensors
and use them instead.
Old Jan 8, 2006 | 12:16 PM
bolton98TA's Avatar
another vote for vett rear o2's, i couldent get my code to go away with extensions and the vett's are plenty long enuff.
Old Jan 8, 2006 | 10:41 PM
Red2000SS's Avatar
Sorry, I am a little confused. Do the 'vette rear O2 sensors come with a long enough wire?
What is the advantage of using the 'vette rear O2 sensors? I have seen people recommend them but never an explanation of why they are different / better.
Thanks for any input.
Old Jan 9, 2006 | 04:26 PM
WILWAXU's Avatar
Vette sensors have a longer harness.
Old Jan 10, 2006 | 04:26 PM
2000SSNB's Avatar
One issue with stock O2 sensors plus extension may be that the
voltage drop along the longer wiring harness will be higher than stock,
so the heating of the O2 will take longer as less voltage drops on the heater inside the sensor (the heating occurs with the square of the voltage).
Thus a longer heating delay might trigger PO135 saying it takes to long to
heat the sensor on cold start. Perhaps the heating element for the corvette
reaches temperature faster with a lower voltage or the wiring is higher gauge
so as to drop less voltage along its lenght.
I have not checked any of this so its pure speculation.
Gert
Old Jan 11, 2006 | 07:49 AM
weestro's Avatar
I used a 12" on the pass side which fit perfect and a 24" on the drivers. 18" is probably what's really needed there...
Old Jan 11, 2006 | 09:46 AM
DirtyJohn's Avatar
12" extensions on both sides.
Plenty of slack.
Old Jan 11, 2006 | 01:25 PM
Plenty of slack.
Are you sure you used 12" extentions for both front O2 sensors?
