QTP cutouts..............
Old Jan 12, 2006 | 12:26 PM
hunterdawgs's Avatar
Default QTP cutouts..............
I'm about to get H/C (TEA stage 2 & Comp cam around 220-224 )and have just ordered cutouts .Will one just after the y-pipe increase the air flow enough or do I need to put both in a little past the headers? I'm also interested in the way both setups sound.Thanks
Old Jan 12, 2006 | 12:46 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
1 in the I pipe in "the niche" is all you need for flow and sound.
I've had both, 1 in the I pipe and 2 in the ORY.
2 in the ORY are very mean, but you lose a lot of ground clearance. Not worth it IMO.
1 in the I still sounds mean and will outflow your muffler, and there's some scavenging done in the Y-merge that's beneficial. Plus you have no cats, so there's no restriction.
Old Jan 12, 2006 | 01:34 PM
SgtB's Avatar
I agree just put one in the I-pipe...that's all i have and it works best because of the scavengaging done in the y merge as stated above
Old Jan 12, 2006 | 07:18 PM
slimcracka's Avatar
will the qpt cut out fit over a cat back or just butt up to it and weld it?
Old Jan 12, 2006 | 07:29 PM
!LS1 11 Second Club
The cutout replaces about a 1' segment in your exhaust pipe, anywhere you want to put it.
Old Jan 12, 2006 | 07:32 PM
!LS1 11 Second Club
On a 3" catback, the 3" cutout would butt-weld. On a stock I-pipe, it would slip over the 2.75" I-pipe for a slip connection which would then be welded.
Old Jan 13, 2006 | 03:38 AM
chewy99ws6's Avatar
I have just one behind my Y, sounds mean as hell too, I leave it closed until a ricer pisses off his bumble bee then I open it and let him have it. lol
