Question about CUTOUTS
THANKS IN ADVANCE
-Adam
Dual cutouts in the Y-pipe really mess up your ground clearance.
I've had both setups. 1 is good for both power and sound.
Elect. motors control the butterfly valves in the elec. cutouts sold by QTP---->.
Look at their wbesite.
Manual cutouts involve reaching under your car and uncapping a plate with 3 wing nuts.
Manual and elect. cutouts are the same by the way. The only thing that makes the elect. ones elect. are the device that caps the cutout.
Loudness - very.
Mileage - I don't see how this affects your MPG.
Also, cutouts sound like *** at part throttle. Only sound good at idle or at Wide Open Throttle.
Also, open cutouts push your tq peak up in the rev range. They make your "feel" slower when accelerating from a low rpm. They infact open up the exhauast and make more hp and tq as a result, but their advantage is best put to use for high rpm use.
For a near stock daily driver, it will free up a few hp and produce a ton of noise when open. It's up to you if that's something that you want.
